so i have a itx build
cooler master elite 110
and im gonna be traveling soon
Should i carry it with me with my carry-on Bag?
should i put it with my luggage
should i remove GPU before i put it in my bag
Please help me cause i dont want to damage any components!
THANK YOU!:)
https://linustechtips.com/topic/578777-pc-taveling-help/
Put it in your bag, it's better than being thrown around with luggage. Also don't remove anything, that's what the case is made for, protecting your components. Just be nice to it and don't put anything conductive inside/next to it
GTX 1070 - Ryzen 5 3600x - Corsair H100i V2 - 32GB DDR4 3200
Check out my Minecraft channel here!
https://linustechtips.com/topic/578777-pc-taveling-help/#findComment-7566642
First, I would definitely recommend removing the GPU and anything else that is not secure and wrapping it up securely in your luggage. Second, carry the rest of the build as a carry-on.
Desktop: ASUS X99-E WS/USB 3.1 (SSI-CEB) | Intel i7-5960X (OC@5.0GHz) | Dual EVGA GTX Titan X Hybrid (2x12GB) | G.Skill Ripjaws V DDR4 (8x16GB@3.4GHz) | Samsung 950 Pro (512GB); WD Black (6x6TB; NAS) | SuperFlower 1600F14HT (1600W; 80+ Titanium)
LD PC-V10 (Black; Reversed; Tempered Glass Mod) | Triple Dell S2716DG (3x1440p@144Hz); Crossover 554K (2160p@60Hz) | LD Phase Change; Noctua NF-F12 iPPC-3000 (x6) | DasKeyboard 4 Ultimate (MX Green Mod; Thick PBT Mod) | Logitech G900; SentrantPC Desk Mat
Audio-Technica ATH-R70x (470Ω); Schiit Gungnir DAC; Schiit Mjolnir 2 AMP (6BZ7 Tubes Only); Audio-Technica AT4040; Behringer XENYX X1204USB Analog Mixer; Yamaha RX-A750 Receiver; Dual Yamaha NS-6490; Dual Yamaha NS-SW300 | Microsoft Windows 10 Pro
Laptop: Lenovo ThinkPad P70 | Intel Xeon E3-1505Mv5 | Nvidia Quadro M5000M (8GB) | DDR4 ECC (4x16GB@2133MHz) | Samsung 950 Pro (512GB); Samsung 850 Pro (2TB) | 17.3" IPS Non-Touch (2160@60Hz) | Sierrra Wireless EM7455 | Microsoft Windows 10 Pro
https://linustechtips.com/topic/578777-pc-taveling-help/#findComment-7566646
Thanks for the help,
but should i but the gpu in the Bag it came in (Anti static bag)???
https://linustechtips.com/topic/578777-pc-taveling-help/#findComment-7566692
Yes and then wrap that in something that will absorb impacts like bubble wrap.
i7-7700 | Asrock H270M-ITX | Fractal Design Core 500 | 16GB Corsair Vengeance LPX | EVGA GTX 1080 Ti | 850 EVO 500GB | 850 EVO 250GB | WD CavGreen 2TB
EVGA SuperNOVA 550W | Steel Series Elite Prism | Final mouse 2015 | WASD Keyboards V2 (MX Blue) | Acer Predator 1440p 144Hz
https://linustechtips.com/topic/578777-pc-taveling-help/#findComment-7566710
It will help if you still have the original box the GPU came in, so toss that in the anti static bag if you have that, then toss that in the original box. That's what that box is made for. At the very least remove the GPU from the motherboard because if it is in the PCI slot and it gets bumped too hard, the PCI part will snap off or bend pretty bad. Any other heavy parts that go in PCI slots would be good to take out as well.
I'm not SAV1OUR. I promise. | Number of successfully bricked phones: 1 Samsung Galaxy S5 | 01001001 01110100 00100000 01110111 01100001 01110011 00100000 01100001 01101100 01101100 00100000 01100001 01101110 00100000 01100101 01101100 01100001 01100010 01101111 01110010 01100001 01110100 01100101 00100000 01110010 01110101 01110011 01100101 00101110
https://linustechtips.com/topic/578777-pc-taveling-help/#findComment-7567268
