Okaaaaaay... As I'm sure many of you have seen, I watched Linus's video of him making a computer on the underside of a desk. Pretty sick video. But, this inspired me to want to build one on a wall! I'm super excited and even if it isn't a great computer as long as it's sturdy and can play a game or so I'll be amazingly happy!!!! If anyone has any suggestions for parts to use (that aren't too pricey) and any tips on how to build something like this I'll be open to any and all tips! And I want as much help as I can get so spread the word! Thanks!
https://linustechtips.com/topic/578581-wall-pc-build/
11 minutes ago, nskceaj said:
I think theres a Case from Thermaltake which can be wall mounted
edit: http://www.newegg.com/Product/Product.aspx?Item=N82E16811133283
I don't really want a case. Figured I'd do similar thing as Linus did with the desk but on a wall.
https://linustechtips.com/topic/578581-wall-pc-build/#findComment-7564627
55 minutes ago, kalious78 said:
sheet of summit like this in a colour of your choice http://www.plasticsheets.com/colour-perspex-sheet/ slap the stuff on it n hang it up, could even use a clear piece and some kinda pillars to make summit similar to the case that chap linked u
What are those?
https://linustechtips.com/topic/578581-wall-pc-build/#findComment-7564838
3 hours ago, TITANB said:
Make shire to get lots of cable tires and collectors so the cable management wood be great BC it is open and shown... Also get semi/full modular PSU for clean and tidy look
I cant find a fully modular PSU... Which I agree would look really tight but can you suggest one that's under $120 at most?
https://linustechtips.com/topic/578581-wall-pc-build/#findComment-7566787
