Hello all.
Every few minutes I can hear water moving in my AIO , yes I know water is moving but every so often regardless of what I am doing I can hear the water move around.
Its about as loud as pouring a glass of water and lasts maybe 3 seconds . Ive looked at the fittings and its not leaking and did a paper towel test and its all good.
Its AIO so I cant exactly top it up so should I be worried?
https://linustechtips.com/topic/577398-aio-making-trickling-sounds/
Whats the brand and model?
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
5 minutes ago, k1ng_alex said:
maelstorm 120k
Seems like a good brand.
I was always under the impression that AIO's were pretty much full of liquid.. not sure how it is trickling.
But if it isn't leaking and your temps are good, I wouldn't worry about it.
the rad it mounted above the cooler/pump so im guessing its just air
