OC Help
Go to solution Solved by KettyKoala,
The downside to using preset OC's is that they set the voltage way too high which skyrockets temps, don't do it. You need to do some more research my friend
So I have an i7-4790k on a ASRock Z97 Fata1ty Killer Mobo cooled by the Dark Rock 3. So I was planning to OC it to 4.2-4.4GHz. However I don't like how when I OC it, the CPU is always pinned to the OC. I don't like it. Is there anyway to have to OC and keep the dynamic multiplier? Like the Clock speed changes based on workload with the OC.
Do you play football/soccer?
Cause you look like a left-back
https://linustechtips.com/topic/576539-oc-help/
It still does this with intel speedstep enabled
i5-6600k @ 4.9Ghz | Corsair H110i GTX + 2 x Noctua NF-A14's | ASUS Maximus VIII Ranger |
Corsair Venegance DDR4 8GB | ASUS GTX 970 Strix |Samsung 840 EVO 240GB + 1TB HDD |
Corsair RM850 | NZXT H440 Black | 2 x Noctua NF-F12 + Corsair AF-140
https://linustechtips.com/topic/576539-oc-help/#findComment-7542338
Set the power plan to balanced instead of performance in your control panel :)
https://linustechtips.com/topic/576539-oc-help/#findComment-7542349
OC to 4.24/4.3. Ran 10 pass Standard Intel Burn. Hottest CPU ran at 93 degrees celsius thoughts?
https://linustechtips.com/topic/576539-oc-help/#findComment-7542393
What voltage are you running? That's really high to say you haven't really OC'd it much
https://linustechtips.com/topic/576539-oc-help/#findComment-7542397
Ran another 10 pass https://gyazo.com/da7e99df8c2b6353c7973aa9024d4474
All Cores set to 43 other settings all on auto
https://linustechtips.com/topic/576539-oc-help/#findComment-7542411
Change your voltage manually. You should REALLY research before doing this stuff, its ridiculous people think you can just do this without any concequences
https://linustechtips.com/topic/576539-oc-help/#findComment-7542424
Thats why I'm at LTT. Experience
https://linustechtips.com/topic/576539-oc-help/#findComment-7542427
You will be experiencing some feels when your CPU is fucked..
https://linustechtips.com/topic/576539-oc-help/#findComment-7542455
Okay changed a couple settings turns out input voltage was locked at 1.9V. New 10 Pass but 4.2GHz OC now. https://gyazo.com/00449d2546a52fcc6314f55b370981de\
Also downsides to using BIOS preset OCs?
Edited by Rienks
Added Info
https://linustechtips.com/topic/576539-oc-help/#findComment-7542459
Input voltage has nothing to do with it
https://linustechtips.com/topic/576539-oc-help/#findComment-7542470
https://linustechtips.com/topic/576539-oc-help/#findComment-7542501
