Lower Microphone Gain Level through software problems
Solved by iNoa97,
2 hours ago, GER_T4IGA said:Do you have AGC enabled? How is that Blue Yeti connected to your system? Skype has a setting to auto adjust the volume. Disable that maybe? idk ...
I don't know how to enable/disable automatic gain control, the blue yeti is connected through a 3rd party Mini USB cable I had lying around, I lost the one that came with the yeti, and Ill check the audio settings in skype.
e: OK so in Skype call tab there's a section with audio settings and I disabled automatically adjust audio levels, and I realized from what I said from my original problem, when I control the sound level through the sound app, it adjusts the Skype level one too so I think I've got it figured out now
