so im rendering in davinci and its only using 50 ish % cpu usage and 10% gpu, and 7gb ram. why not 100%?
My rig: r7 1700 @ 3.9/1.35v, 16gb ddr4 3200, assorted rando SSDs, hx 1050, vega 64 1650/1025
MY $75 BUILD https://linustechtips.com/main/topic/576889-the-75-build-log/#comment-7547280
https://linustechtips.com/topic/575320-davinci-resolve-only-using-50-cpu/
You can use MSI Afterburner to see if anything else is maxed out.
But it might just be your render settings.
Side note, how do you like Davinci Resolve?
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
no. gpu is like 10%, ram has a gb spare.
how do I change my render settings?
And yes I love it. having only every used movie maker this thing is amasing
Besides GPU, Ram, and CPU. Like temp, for example.
In the 'Deliver' tab, what are your 'Format' settings?
no. temps are all good.
I have the format settings as quicktime 720 30 medium.
In task manager, go to the 'Performance' tab, right click the graph and Change Graph to > Logical Processes.
Post a screenshot of it while its rendering.
screenshots are hard as im using 3 monitors, but all 4 threads have a 50-60% load. that was the first thing I checked
Alt + prnt screen takes a picture of the currently selected window.
But that's strange, not sure why it's doing that.
If I had to guess, you're out of memory. Sure, its not at 100%, but it might be limiting itself. Try closing chrome while rendering.
did that no change. it was running at 6.9 of 7.9gb
I don't suppose you have that $30000 editor panel thing?
no hell no
