Ideally around the 600-650W mark for one R9 390X. About 850W for two.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/575004-how-many-watts-do-i-need/#findComment-7527853
3 minutes ago, JacobKS said:
how many watts do I need for a single Powercolor DEVIL R9 390X?
and  how many watts do I need for a crossfired Powercolor DEVIL R9 390X?
This is a fairly accurate calculator. I usually add 100W just to be sure though. http://outervision.com/power-supply-calculator
Then use this to pick out a good PSU that will last you a long time. https://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/
CPU: i7-8700K I CPU Cooler: Noctua NH-D15 GPU: ROG Strix 1080 Ti MoBo: ROG Strix Z370-E RAM:  G.SKILL Ripjaws V Series 32GB (2 x 16GB)   PSU: CORSAIR HXi Series HX1000i Case: Corsair Air 540 Display: 24" 1920X1080p 144Hz ASUS - 27" 2560X1440p 144Hz Dell OS: Windows 10 Home 64bit
https://linustechtips.com/topic/575004-how-many-watts-do-i-need/#findComment-7527856
An ASS TON. IT IS AMD. IT WILL BURN IN A SECOND. NEVER GO AMDDDDDDDDDDDD. JK, amd fan boy here.
Follow the dude above, he said it perfectly.
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
https://linustechtips.com/topic/575004-how-many-watts-do-i-need/#findComment-7527868
The actual card and, say, a Skylake i7 should run at around 400W under load so use that however you will. I'd recommend the EVGA 750B2 or 650W GQ as they're both cheap and both are great PSUs.
https://linustechtips.com/topic/575004-how-many-watts-do-i-need/#findComment-7529014
