Ok now I have really run out of ideas, since i failed to get a display from my 280. Basically i switched it out for my friends old 5870 to test its performance, and when i switched it back i just could not get a display. i wiped the old drivers using DDU,  but once i had done that i could not get it to even detect my graphics card was plugged in! Which sucks as I'm now stuck using the 5870, not a bad card just not a 280... Before anyone asks the monitor works, the cable works and the fans whir up and the connections are properly seated. If anyone has any ideas what to do next please help me by posting a comment.
https://linustechtips.com/topic/574671-280-help-again/
Did you touch the PCB of the card?
https://linustechtips.com/topic/574671-280-help-again/#findComment-7524485
Just now, Boyce05 said:
Sorry for such late response, no i didnt
Hmmm. Did you have the PSU switched off and were you grounded?
https://linustechtips.com/topic/574671-280-help-again/#findComment-7534141
Yup
Well something killed it, just a matter of figuring out what
https://linustechtips.com/topic/574671-280-help-again/#findComment-7534176
