Asus m5a97 r2.0 beep code issue
Go to solution Solved by Creeper1372677,
OP has fixed their problem
google this error i'm googling it right now
you should get some thing or check the manual
Cpu: Intel i7-5820k at 4.6 Ghz // Motherboard: Asus X99 Pro // Ram: 32gb of Crucial Balistix at 2400 Mhz // Gpu: GTX 1080 Founders Edtion // SSD: Samsung 850 evo 250gb, Samsung 950 pro 256 gb, // Cooler: Cooler Master ml240r // Case: NZXT h500i
i checked the manual and saw nothing and google did not help much either
if you cant find anything call asus
