A question about airflow + s340
Solved by Savir,
2 minutes ago, かあびぃ said:Hey.
I'll soon be getting a h100i v2 to replace my current Hyper 212 as the cooler for my 5820k. I'll put 2 sp120's on the h100i, and replace the two NZXT stocks in the case with AF120's.
How should i arrange the airflow though?
This was my plan:
Top: intake
Rear: exhaust
Two on radiator: intake
What do you think?
Well thats ok, but I would prefer the top to be exhaust since hot air rises. This would make it easier for hot air to leave the case. 2 exhaust and 2 intake is usually what people do.
