The Zotac GTX 970 Extreme AMP! Edition Card has been giving me lots of issues stability wise for the past couple of months. I just realized the voltage is restricted on the card to 1.21v. Now this is a lower restriction that was present with the reference and competitors cards. Is there a way I can bios flash this card to increase the voltage to its original limit. I swear this card has everything to help it OC stupid high but is limited by its current bios.
Normal Factory OC:
CORE CLOCK 1404
MEMORY CLOCK 1800
VOLTAGE Lower than 1.2124 (Stable but why?)
Idle temps 38-42 C
Load temps 52-56 C
OC settings:
CORE CLOCK 1494 Mhz
MEMORY CLOCK 1930 Mhz
VOLTAGE 1.2124 (Not high enough to keep it stable for 2+hours)
Idle temps 38-42 C (Based on ambient room temps)
Load temps 52-56 C (Based on Ambient room temps)
Sexy Beast named War Machine: http://pcpartpicker.com/b/M2Pscf
https://linustechtips.com/topic/570525-gtx-970-voltage-issue/
That's my issue. I can't find a custom bios for the Zotac 970 Extreme AMP! Edition. I've been looking and I haven't really had much luck. If I can find one I can OC this card even higher and have it stable always. Actually if I had that extra headroom I'd be able to get this card to 1515 Mhz no problem. I would customize my own if actually knew how. :(
https://linustechtips.com/topic/570525-gtx-970-voltage-issue/#findComment-7484041
