What Graphics Card To Get? Please Help.
Solved by FX-9590,
The Gigabyte GTX 950 is my recommendation https://ca.pcpartpicker.com/part/gigabyte-video-card-gvn950oc2gd
Although I still have to learn about this external pcie slot stuff so I would try and make sure that everything will be compatible with your laptop and the external pcie slot itself.
Ray1ce ·
Posted in Troubleshooting6 -
1
Forvirrad ·
Posted in New Builds and Planning7 -
MiszS ·
3
1
2
Liberty610 ·
Posted in CPUs, Motherboards, and Memory4 -
1
play_circle_filled
Latest From Linus Tech Tips:
AMD Is Copying The Worst Thing About Intel - WAN Show May 31, 2024
