Hey guys, I recently got a vst(a virtual instrument for music production) specifically called Hypersonic 2 from a friend. I am afraid i got malware or maybe a virus but perhaps im just being paranoid. I looked in the folder and everything seemed normal after installation except for a " rwdef.file " i googled it and a website popped up called malwr.com and has a explanation in technical terms what is it but i have no clue if it is malware or not, can someone check it out and explain it to me? the link is- https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&cad=rja&uact=8&ved=0ahUKEwjtvePK08vLAhXLNSYKHS13AFkQFggzMAQ&url=https%3A%2F%2Fmalwr.com%2Fanalysis%2FMGQ1ODUzMTcxZTU4NDk5NTg4MTI0YmEwOWNmYzUzNjI%2F&usg=AFQjCNEEi-XOMp_vrORIKWafAVVOZa_tMg&sig2=Pl277u4nXlfbt6mp38QfVw&bvm=bv.117218890,d.eWE
 I deleted that weird file anyway and im about to delete the vst itself but i am hoping no malware was installed on my computer. What are some symptoms of malware? my pc seems fine so far( i am on windows 8 but bootcamp from my macbook). Do you know how to check if i did get malware? any free anti virus recommendations?
https://linustechtips.com/topic/567817-help-malware-or-virus/
Run Malwarebytes
https://www.malwarebytes.org/
it's free and it works really well
Motherboard - Gigabyte P67A-UD5 Processor - Intel Core i7-2600K RAM - G.Skill Ripjaws @1600 8GB Graphics Cards  - MSI and EVGA GeForce GTX 580 SLI PSU - Cooler Master Silent Pro 1,000w SSD - OCZ Vertex 3 120GB x2 HDD - WD Caviar Black 1TB Case - Corsair Obsidian 600D Audio - Asus Xonar DG
   Hail Sithis!
https://linustechtips.com/topic/567817-help-malware-or-virus/#findComment-7457243
Just now, alien808 said:
awesome thanks for the quick reply!
yepper.
   Hail Sithis!
https://linustechtips.com/topic/567817-help-malware-or-virus/#findComment-7457391
