So my roommates laptop is having problems from switching from speakers to mp3 jack and back. Troubleshooting doesn't work, there is no audio device driver to rollback or update to and can't seem to find the driver in the program files. :|
Anybody have a clue?  this just started after a FORCED UPDATE TO WINDOWS 10.... windows didn't even ask it just did it.....
edit: only way to get them to work is to force enable and make the speaker or jack to be default....
also halp otherwise he will buy a mac :|
https://linustechtips.com/topic/566579-problems-with-audio-from-a-laptop/
Do you have the laptop's brand and model? I can help you find the appropriate drivers.
Current rig :  |CPU: 2600K @ 4.8GHz|   |GPU: EVGA ACX GTX 980 @ 1.5GHz| |Ram: 16GB G.Skill Ripjaws X|   |Storage: Samsung 840 Pro 256GB, WD Blue 500GB, WD Black 1TB|  |Motherboard: AsRock Z68 Extreme4 Gen3|   |Cooler : Black Phanteks TC14PE (3 Corsair AF140s)|   |Power Supply : Thermaltake TPG-850M|  |Case: Phantom 410 Black|
its a sony vaio laptop and no idea what the sku numbers its that old :|
Every laptop is different, I have to know the model number if you can find it. Can you read off any clues as to what model you have? Are the numbers completely gone?
yea :|
There's no point now.... he's getting a mac :(
poor guy, welp.... I'd recommend an HP Spectre, since he wants a mac :D
