So I recently bought a Swiftech H220 X2 and I noticed a small "buzzing noise". I thought that it was a wire on a fan but upon closer inspection I learned that it was in fact an air pocket on the actual CPU block that was vibrating.
I have tried to move the case while it is running to get the bubble out of there and when the system is under load the bubble is still there but the noise goes away.
Is there any way to get rid of this annoying bubble or am I doomed to have a buzz for as long as I have this cooler?
As always, thanks for the help :D
CPU: i7-8700K I CPU Cooler: Noctua NH-D15 GPU: ROG Strix 1080 Ti MoBo: ROG Strix Z370-E RAM:  G.SKILL Ripjaws V Series 32GB (2 x 16GB)   PSU: CORSAIR HXi Series HX1000i Case: Corsair Air 540 Display: 24" 1920X1080p 144Hz ASUS - 27" 2560X1440p 144Hz Dell OS: Windows 10 Home 64bit
https://linustechtips.com/topic/566098-slight-issue-with-aio/
There´s a good chance that the air will move eventually after a while. That happens a lot of times with watercooling. Even when you try to bleed the air out 100% you´ll still have some remaining for a while. Usually it will eventually go into the res or radiator and never be much of an issue again. I don´t think you´d have any reason to be worried.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/566098-slight-issue-with-aio/#findComment-7438177
I'm not really worried about it but it is quite annoying right now... well let's hope it won't be there for very long.
https://linustechtips.com/topic/566098-slight-issue-with-aio/#findComment-7438364
Yeah I know how you feel... that sound is annoying.
https://linustechtips.com/topic/566098-slight-issue-with-aio/#findComment-7438373
Okay so I don't think that it's the bubble because that's gone and it's still making the noise. I think it may be the pump but I don't know of a way to check if it is or not. Also I don't know if there is any possible "fix" to this either. Any thoughts?
https://linustechtips.com/topic/566098-slight-issue-with-aio/#findComment-7438982
What is the pump speed?
https://linustechtips.com/topic/566098-slight-issue-with-aio/#findComment-7439003
1200-3000 PMW controlled
https://linustechtips.com/topic/566098-slight-issue-with-aio/#findComment-7439041
Would that make any kind of difference?
https://linustechtips.com/topic/566098-slight-issue-with-aio/#findComment-7439068
I know. I mean what speed your pump is running?
The pump is very quiet under 2,000rpm. But very noisy at 3,000rpm.
Think about it. A Corsair H105(Asetek based) pump, which is much smaller than the Swiftech pump, runs at 1,800rpm, is enough to push one radiator and a CPU block. Unless you have more components. You can pretty much set the pump speed to 1,700 to 1,800rpm and forget it.
https://linustechtips.com/topic/566098-slight-issue-with-aio/#findComment-7439075
I have no idea nor do I have any idea as to how to find that information out.
https://linustechtips.com/topic/566098-slight-issue-with-aio/#findComment-7439082
3 minutes ago, Deli said:
If you do plug the PWM signal cable of the pump to the motherboard PWM fan header. You can see the pump speed in the BIOS, and adjust it if needed.
Would the optional CPU 4 pin connector work for this?
https://linustechtips.com/topic/566098-slight-issue-with-aio/#findComment-7439113
Depends on your motherboard. My mobo(also from Asus) CPU OPT is only a slave to the master CPU header. But yours may be different. Check the menu of your mobo. Or, you can use other fan header(for case fan) as long as it is(can be) PWM controlled.
https://linustechtips.com/topic/566098-slight-issue-with-aio/#findComment-7439135
Okay so it was deffinetly the pump running at a low RPM that was causing that issue. After some tricking that I had to do to get the thing to recognize that there was actually a CPU fan. I have the pump connected to one of my PWM chassis fan connectors and there is no longer that raddling. It's slightly louder than before but much less annoying :D
Thank you for all your help.
https://linustechtips.com/topic/566098-slight-issue-with-aio/#findComment-7439199
