Max Motherboard Memory?
Go to solution Solved by Neokolzia,
Most boards just have that advertised as a standardized max stick.
8gb sticks are common, 16gb sticks aren't, I don't think there would be any issue, just the manifacturer likely never tested it.
Keep in mind Windows 10 Home, has a 128gb limit I think? and Pro 512gb.   I know the x99 boards show 16gbx8slot setups typically in "maximums".
Most / All motherboards have a Max Memory on their information. the particular motherboard i am looking at ( http://bit.ly/22hAOEe ) has 8 DDR4 Ram slots, but only lists a maximum of 64 GB RAM. (8x 8gb Sticks). What if i were to put 16GB sticks of ram into the motherboard? would it post, and would a system running on more than the Max amount of RAM be stable?
also, what caps out the RAM in general?
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/565746-max-motherboard-memory/
1 minute ago, IsaacDaGrazin said:
I think it would post, just it wouldn't allow you to use the extra ram, or it will not show it.
I have no idea if tennis is true, sun trust meh
:o dis is meh 1000 post
Thank you for your service!
Regarding OP - if it posts there is a chance it will not address and display all of the memory. Potential that it will not post because the ram modules are too large. Additionally, that may be the original spec on the board. A firmware update might have changed that as well.
浪速の建てるは静か用に建てました!- Build Log Coming Soon!
https://linustechtips.com/topic/565746-max-motherboard-memory/#findComment-7434709
Interesting. is there any reason why a board wouldn't be able to support 16GB sticks? or is it just unimplemented software.
could i buy a board, and then have the Max memory change?
Laptop:
https://linustechtips.com/topic/565746-max-motherboard-memory/#findComment-7434714
Could be a physical limitation for some reason. Could be unimplemented in bios at the time of release because 16gb sticks were not available for testing and validation. No guarantee that it will work with a larger memory specification unless you get the manufacturer to tell you that it will work...or if there is a firmware bios update that says that it adds that feature. If you need such a large memory pool you might want to look for a board that you know for sure will support it.
https://linustechtips.com/topic/565746-max-motherboard-memory/#findComment-7434725
https://linustechtips.com/topic/565746-max-motherboard-memory/#findComment-7434930
