i'm trying to make a simple circuit where i flip a switch on my desk, which will cause an arduino to send data to an rf transmitter that will be received above my door to activate a transistor and allow power to flow turning on a red led.  I don't want to have an arduino at the receiver end, so can I connect the transmitter to arduino pin 9(just as an example) write pin to as HIGH, have the reciever receive that HIGH signal and have that open the transistor?
I can help with programming and hardware.
<Script>alert("This website is vulnerable to XSS");</Script>
https://linustechtips.com/topic/565454-rf-receiver-to-switch-transistor/
Well, if the receiver has an analog output, just hook that to the base of the transistor to make it work.
