So my mobo (asus b85 pro gamer) was acting faulty bios got really slow and and i think its breaking
If found a video on youtube and i think it might fix it. is this okay? ty
Chassi:Fractal Define S Mobo:Z97 anniversary Cpu:I5-4670k@4,2 ghz Gpu:Gigabyte g1 970 Cpu Cooler:Hyper 212 evo Ram:16 gb 1600 mhz ddr3 crucial SSD:Samsung 850 evo 250gb 2x
https://linustechtips.com/topic/565449-motherboard-fix-ok/
Consider baking it. Also Try to solder the pins on the socket back together, since their obviously ripped apart. What CPU are u using? I would bake it aswell, just to be sure it is working correctly.
Budget Rig "Curable":     | FX 6300 @4.5Ghz | Asus R9 270x | Asus Crosshair IV Extreme | 16GB HyperX Beast | 120GB PNY SSD
Tablet "Buddy":                 Trekstor Wintron 10.1|
https://linustechtips.com/topic/565449-motherboard-fix-ok/#findComment-7431346
I have tested all my components on other systems and they have worked fine, im pretty sure its the mobo. It also is really laggy in bios and i have ALOT of small issues
https://linustechtips.com/topic/565449-motherboard-fix-ok/#findComment-7431365
have you umm thought of rma ?
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
https://linustechtips.com/topic/565449-motherboard-fix-ok/#findComment-7431476
i dont have recepit
https://linustechtips.com/topic/565449-motherboard-fix-ok/#findComment-7431563
1 hour ago, Changrai said:
i dont have recepit
you dont need a receipt for rma.. you give them the serial number and your info, and send it out, you contact asus not the retail store you got it from
and a car thread !
https://linustechtips.com/topic/565449-motherboard-fix-ok/#findComment-7432098
