Title says it all. It's really making me mad and I can not figure out what it is. Please help. :c
Computer Specs: CPU: i7 3770k, GPU: EVGA GTX 770, PSU: Corsair HX 850W, Case: Fractal Design R4, Motherboard: MSI Z77A-GD65, RAM: Corsair Vengeance 16GB 240 Pin DDR3, Corsair H100i Liquid CPU CoolerKingston HyperX 240GB SSD (OS), WD 1TB HDD Black Edition
https://linustechtips.com/topic/56095-cpu-usage-at-50-when-idle/
post your taskmanager please
Just a sec.
https://linustechtips.com/topic/56095-cpu-usage-at-50-when-idle/#findComment-756980
do you have a sevice running background? open up task manager an see wat is taking so mutch procces power in use. or reboor the system. if that is not the case reset bios to default settings.
EOC folding stats - Folding stats - My web folding page stats
Summer Glau: Quote's The future is worth fighting for. Serenity
My linux setup: CPU: I7 2600K @4.5Ghz, MM: Corsair 16GB vengeance @1600Mhz, GPU: 2 Way Radeon his iceq x2 7970, MB: Asus sabertooth Z77, PSU: Corsair 750 plus Gold modular
My gaming setup: CPU: I7 3770K @4.7Ghz, MM: Corsair 32GB vengeance @1600Mhz, GPU: 2 Way Gigabyte RX580 8GB, MB: Asus sabertooth Z77, PSU: Corsair 860i Platinum modular
https://linustechtips.com/topic/56095-cpu-usage-at-50-when-idle/#findComment-756981
Press CNTRL + Shift + esc, then sort by CPU usage bc255a5387bfbfefc21871f410185a11.png
That way you can see what's using up your CPU.
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/56095-cpu-usage-at-50-when-idle/#findComment-756982
https://linustechtips.com/topic/56095-cpu-usage-at-50-when-idle/#findComment-756987
kill lsm and reboot.
https://linustechtips.com/topic/56095-cpu-usage-at-50-when-idle/#findComment-756999
are that all the processes? how hot is your cpu getting? with what cooler
Its averaging 53 Celcius.
https://linustechtips.com/topic/56095-cpu-usage-at-50-when-idle/#findComment-757001
I get 60 frames at 1080p on a dual core APU. Ask me how.
AMD FX 8350 CPU / R9 280X GPU / Asus M5A97 LE R 2.0 motherboard / 8GB Kingston HyperX Blue 1600 RAM / 128G OCZ Vertex 4 SSD / 256G Crucial SSD / 2T WD Black HDD / 1T Seagate Barracude HDD / Antec Earthwatts 650W PSU / Coolermaster HAF 922 Case
https://linustechtips.com/topic/56095-cpu-usage-at-50-when-idle/#findComment-757004
4qsIv.jpgLsm is one sneaky bastard.
https://linustechtips.com/topic/56095-cpu-usage-at-50-when-idle/#findComment-757010
I noticed lsm.exe. try ending the process.
Thank you my good man. :)
https://linustechtips.com/topic/56095-cpu-usage-at-50-when-idle/#findComment-757013
is it fixed now?
Yes sir, I had no idea lsm was doing that, it wasn't doing it earlier in the day.
https://linustechtips.com/topic/56095-cpu-usage-at-50-when-idle/#findComment-757026
read my link because sometimes just stopping a process in the task manager is not a good idea if you do not fully know what the process is.
https://linustechtips.com/topic/56095-cpu-usage-at-50-when-idle/#findComment-757027
and also chek that lsm is not starting up when windows starts up go to start menu icon on search typ in msconfig press enter then go to tab, startup bar and sevices chek if lsm is marked unmark it and aply and reboot.
https://linustechtips.com/topic/56095-cpu-usage-at-50-when-idle/#findComment-757035
I can't seem to find it in the msconfig. Hmm...
https://linustechtips.com/topic/56095-cpu-usage-at-50-when-idle/#findComment-757056
then reboot the system and see if it occurs again.
https://linustechtips.com/topic/56095-cpu-usage-at-50-when-idle/#findComment-757063
I did and it started back up again. It's hiding somewhere...
https://linustechtips.com/topic/56095-cpu-usage-at-50-when-idle/#findComment-757065
What is LSM?
i5 4670k | Sapphire 7950 | Kingston 120GB SSD | Seagate 1TB | G.Skill Ripjaw X Series 8GB
PB238Q | Steelseries Sensei | Ducky DK9087 | Qck Heavy
Build Log: http://linustechtips.com/main/topic/44902-from-imac-to-my-own-creation/
https://linustechtips.com/topic/56095-cpu-usage-at-50-when-idle/#findComment-757071
ok then go to start menu typ in services and go to component sevices then to -----> services (local) find lsm and go in to that if it is there then startup type disabled.
https://linustechtips.com/topic/56095-cpu-usage-at-50-when-idle/#findComment-757078
What is LSM?
Local Session Manager
https://linustechtips.com/topic/56095-cpu-usage-at-50-when-idle/#findComment-757079
