Ok, so I just overclocked my GPU to 1514 MHz and I was curious about something. Does MSI Afterburner need to be open for the overclock to take effect when I boot up my computer?
Nocturna(Main Computer): CPU: i7-4790K    GPU: MSI GTX 970 4G    MOBO: ASRock Fatal1ty Z97 Killer     PSU: CX500(For Now!)    Case: Enthoo Pro M    RAM: N/A(I don't really know anything other than it's 12GB total, it's a mixture...)    CPU Cooler: Stock i7-4790K Cooler(For Now!)
UPGRADES IN PROGRESS:
PSU: EVGA SuperNOVA 750 P2 80+ PLATINUM  RAM: Corsair Vengeance Pro 16GB DDR3 2133 MHz   CPU Cooler: Corsair Hydro Series H100i v2  GPU: GTX 980 Ti
https://linustechtips.com/topic/559894-overclocking-help/
If you press the Apply OC at windows startup then it will do it but idk if it applies the OC with afterburner off
https://linustechtips.com/topic/559894-overclocking-help/#findComment-7369603
