Upgrading GPU. need some help
Go to solution Solved by mangeHD,
yes that is fine it say on the calculator 479w with the new i7 non oc and a high end water cooler
so my current PC:
CPU: i5 3470 3.2Ghz
GPU: GTX 760 2gb
Storage: Samsung SSD 850 EVO 2.5 SATA III 500GB, WD green 500Gb, WD Green 3Tb
Power Supply: Antec 550w
Semi New Build:
CPU: i5 3470 3.2Ghz
GUP: GTX 970 4gb
i need to know. is that power supply enough for the semi new build? should i get a 850w corsair power supply future proofing because later this year i wanna get an i7 3770k with liquid cooling..
Intel® Core™ i7-6700K 4.9Ghz | MSI RTX 2070 Gaming Z | 32GB Corsair DDR4 3200Mhz | Samsung M.2 970 EVO nVME 256GB | 960 EVO 256GB SSD | WD Black 4TB 7200RPM HDD | WD Black 8TB 7200RPM HDD | Corsair Obsidian 500 RGB | Zalman 850w Gold
Alienware 244Hz 25" 1080p, Asus 144Hz 25' 1080p, LG 4K OLED 65' TV | Razer BlackWidow V2 Chroma Keyboard | Razer Mamba TE Chroma Mouse | Razer 7.1 Chroma Headset | Razer FireFly ClothEdition Chroma MousePad
https://linustechtips.com/topic/559636-upgrading-gpu-need-some-help/
Just now, Tautedorus said:
I guess that you should be fine with this PSU.
so should get that 850w later, when i get a new cpu?
Just now, mangeHD said:
hi i just need to know your ram and how many fans you have and if your cpu is water cooled
16gb of RAM, CPU has a stock cooler and my graphics cards fans. no other fans. just my stock cooler on the cpu. and the fans on the graphics card. i wanna get a new case and with it will come 1 120mm fan with red LEDs
hmm thanks..
