Hi Guys,
Any recommendations on a good wireless mice?  At the moment, I'm looking at the Razer Orochi, but unfortunately we don't have a nearby store wherein I can check how it feels on the hand.
It would be good if you can suggest awesome mice which has ergonomics too, as I am starting to experience pain in my wrist.
Thanks!
https://linustechtips.com/topic/559514-wireless-mouse/
13 minutes ago, rikaragoza said:
Hi Guys,
Thanks!
Just wanna point out that a wireless mouse is not as good as a cabled mouse for gaming. But i'm sure that you are aware.
Check out the Logitech G602, its also wireless. I dont have it myself, but i heard good about it.
Yes, the username is cringe.
https://linustechtips.com/topic/559514-wireless-mouse/#findComment-7363987
I hate wireless products. The batteries die at horrible times, teams blame you for ruining the kill, your friends abandon you, then you die alone.
But seriously with wired products: No recharging, no battery dying at inconvenient times, and no signal issues/delays.
The one downside is if you experience wire drag in which case a simple product like:
http://amazon.com/dp/B004K2WZS4 or any of these:
https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=mouse+cord+bungee&rh=i%3Aaps%2Ck%3Amouse+cord+bungee
and you're sorted.
As for which mouse you use it depends on what you plan on using it for. If you play mmorpgs or anything with an ability rotation/multiple hotkeys I can't suggest the black Corsair Scimitar strongly enough.
https://linustechtips.com/topic/559514-wireless-mouse/#findComment-7366296
