HELP ON PSU
Solved by Wyzzy Moon,
you can't really power 2 systems with 1 PSU. You simply don't have 2 24pins so you would need to make a lot of custom cables to make that work and than it is really easy to mess up and fry your systems if you don't know what your doing. So get 2 separate PSU's.
600 could do it but 750 to be safe maybe
YoungBlade ·
Posted in CPUs, Motherboards, and Memory7 -
2
derekchan ·
Posted in New Builds and Planning7 -
6
5
7
kerriya ·
Posted in Cases and Mods11
play_circle_filled
Latest From ShortCircuit:
