key problems.. from enterprise to pro ?
so I had a key, then I had to get rid of it (problems..)  but now im stuck with a deactivated version of windows 10 enterprise.
I want windows 10 pro, activated.
can I just get a windows 7 home premium key and activate with that ? (or windows 8 pro ?)
will I have to reinstal windows ?
https://linustechtips.com/topic/559227-key-problems-from-enterprise-to-pro/
Your key has to match the version of windows you have. Except Windows 10 can use their respective Windows 7 and up Edition Key.
Main Gaming and Streaming PC: http://pcpartpicker.com/user/Vinsinity/saved/TjwVnQ
Ultrabook and College Laptop:
XPS 13 9350:
i5-6200U
8GB RAM
Samsung PM951 250GB M.2 Solid State Drive
Workstation Laptop:
Sager NP8672 (P670SG):
i7-4720HQ
32GB (4 x 8GB) CORSAIR Vengeance Performance
Samsung 850 EVO 250GB M.2 Solid State Drive (Boot Drive)
Samsung 950 PRO 512GB M.2 Solid State Drive (Video Drive)
Crucial MX100 250GB 2.5" Solid State Drive (Secondary SDD Storage)
Western Digital (Blue or Black) 1TB 2.5" 7200RPM Internal Hard Drive (Storage Drive)
GeForce GTX 980M 4G
so you can't downgrade
I don't believe so. You have to clean install.
XPS 13 9350:
i5-6200U
8GB RAM
Workstation Laptop:
i7-4720HQ
GeForce GTX 980M 4G
fck.. ok
A Win 7/8.1 key should work on 10 (Unless Microsoft did some douche move recently)
AMD Ryzen 9 5900X | ASUS TUF GAMING X570-PRO | G.Skill Ripjaws V 2x16GB @3600MHz CL16 | AMD Radeon 6800 XT Cooler Master MasterCase Pro 5 w/ Tempered Glass | Samsung 970 Evo Plus 1TB + ADATA SU800 2TB | Corsair HX1000iNoctua NH-D15 chromax.black
8 hours ago, Riki the Legendary Heropon said:
One word: KMSpico
Just make sure you download it from the right website, one of them was good and the other one I downloaded was a crapload of viruses and adware
But yeah a Win 7/8.1 key should work on 10 (Unless Microsoft did some douche move recently)
We do not encourage the use of private software /OS. It's against the forum community standard. If you are upgrading from window 7 /8.1 be sure that you have the matching version of Windows 10 for example
Windows 7 home premium >windows 10 home
Windows 8 pro > windows 10 pro.
Ah sorry. Wasn't aware of that. Edited the reply now
