Could anyone help me with my troubles? I posted yesterday and im still freaking out.  It all started when a couple of bags with books fell on the screen.  Then I noticed the lcds were leaking.  It has gotten just a tiny bit worse.  Where should I take it?  Is something going to break?  I also have a at&t replacement warranty but that's $100 and im saving up for my first build
https://linustechtips.com/topic/557709-led-leak-phone-help/
I'd take it to AT&T and admit defeat to losing your $100. Rather that than wait till you have no AT&T Warranty and fork out a $600+ for a new phone.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/557709-led-leak-phone-help/#findComment-7341931
The warranty might have expired.  Would a visit to CellPhoneRepair be worth it?
9 hours ago, Xenift said:
You would need to pay to get it fixed, however if the smudging isn't that bad,  you can technically live with it for 2 more years or so.
https://linustechtips.com/topic/557709-led-leak-phone-help/#findComment-7344925
Nope, imo a phone repair is never worth.
Unless it's a iPhone and the spares are relatively cheap. (To a certain degree better than android repairing.)
https://linustechtips.com/topic/557709-led-leak-phone-help/#findComment-7347252
