Cable Twisting how to fix??
Solved by W-L,
13 minutes ago, LTB4489 said:Hey just wondering on how to fix this or preventing it from happening. Help would be much appreciated.
Well to remove it you can uncoil it but to prevent it that has to do with the way you wind the cords usually where using the under over method is usually best at preventing that. If that happens during use it's twisting so don't turn the device around when in use many times.
