SSD + HDD setup need help
1 hour ago, Firestrike said:Additionnal info : if I remove the 1st pinned shortcut and pin it back using the duplicated icon, it still makes another icon next to it.
Ok, so interestingly I just remembered that I had this exact issue on my old laptop running Windows 8, and that the only thing that changed it was installing 8.1 when it came out. So my guess is that a reinstall might help. I tried to find a setting for this on my current windows 10 install, but like you was unable to find anything.
What is interesting is that I'd actually like to have it work the way it works for you, I'd rather have them work like static shortcuts rather than how they currently work for me. If you do find the setting, message me or something lol.
Sorry I couldn't be of more help especially since this is something that I have experienced. Wish I could do more.
