What did you download?
My Work in Progress PC http://linustechtips.com/main/topic/522048-xeon-build/ <-- That PC was built but never booted:(
My Work in Progress PC 2.0 https://linustechtips.com/main/topic/540583-xeon-build-20-code-name-xenox (Hopefully this one boots.)
https://linustechtips.com/topic/555967-tech-questions/#findComment-7324829
13 hours ago, pablofahrner1809 said:
i dont know a minecraft texture pack or something and since then it is there and there is also a wierd security thing since then.
It looks like you may have a virus. Download and run this and it should fix it. https://www.malwarebytes.org
https://linustechtips.com/topic/555967-tech-questions/#findComment-7332735
