Will the MSI GAMING 9 ACK let me do the following:
1. Install 2 Titan Xs running in SLI.
2. Install a Samung 950 Pro SSD as a boot drive.
3. Install a secondary Intel 750 Series SSD.
4. Install a network adapter.
Thanks in advance.
CPU: Intel i7-6700k - GPU: EVGA GTX 1080 FTW - Motherboard: Asus Z170-A - RAM: Vengeance LPX DDR4 16GB 3000MHz - CPU Cooler: Corsair Hydro GTX H110i - PSU: EVGA SUPERNOVA 650W P2 - Case: NZXT H440 White/Black - OS: Windows 10 Home - Mouse: Logitech G502 - Keyboard: Corsair Strafe Cherry MX Red RGB
https://linustechtips.com/topic/555871-msi-gaming-9-ack-help/
8x Titan X, 4x Intel 750, 0x, 16x Titan X all works fine.
The question is how the last slot works, when not using all 8 lanes. As that determiner if the Samsung 950 Pro gets CPU lanes or Chipset lanes.
But based on everything I have seen, so will the m.2 most likely not get the CPU lanes do to the priority of the switches.
X99S_GAMING_9_AC(K)_PCIe_lanes_switching
I speak my mind, sorry if thats a problem.
https://linustechtips.com/topic/555871-msi-gaming-9-ack-help/#findComment-7323961
I am a newbie at all this PCIe lanes stuff, so everything you just said completely confused me D:
Can you please give me a simple explanation? xD
Is there any X99 motherboard that will let me all of the things I listed above? Or will the Gaming 9 ACK do the job?
Sorry D:
https://linustechtips.com/topic/555871-msi-gaming-9-ack-help/#findComment-7323990
Sorry D:
Not on the MSI side it seems, as they all have the same "issue".
Use of the last PCI slot robs the M.2 of most of its speed.
https://linustechtips.com/topic/555871-msi-gaming-9-ack-help/#findComment-7324052
Will Asus Rampage V Extreme do the job?
https://linustechtips.com/topic/555871-msi-gaming-9-ack-help/#findComment-7324192
Yes, that will work.
Titan X in first and 3rd red slot. Intel 750 in 2nd red slot. network card in black slot.
1 Titan X will run 8x instead of 16x, most likely, but all cards should get the speed they require.
https://linustechtips.com/topic/555871-msi-gaming-9-ack-help/#findComment-7324229
Alright, thanks :)
Sorry for all the questions, but what about the X99 Deluxe? :D
https://linustechtips.com/topic/555871-msi-gaming-9-ack-help/#findComment-7324444
11 minutes ago, Zack Brown said:
Alright, thanks :)
Nope, not enough slots.
Remember, 2 Titan X's take 4 slots, including spaces. Asus Rampage V Extreme has space between 1th and 2nd Red slot, so you can place a card into both.
https://linustechtips.com/topic/555871-msi-gaming-9-ack-help/#findComment-7324471
Aha, thanks.
When you talked about the Rampage V Extreme you did not mention the Samsung 950 Pro
https://linustechtips.com/topic/555871-msi-gaming-9-ack-help/#findComment-7324478
1 minute ago, Zack Brown said:
Aha, thanks.
"40-LANE CPU: The PCIeX8_4 slot can only be used in x4 mode or lower when used simultaneously with the M.2 connector. If x8 mode is used, the two connectors will be mutually exclusive."
Put the Intel 750 in the lowest Red slot and it will be fine.
Along with Titan X in first, Titan X in 3rd red slot and network card in black slot, of course
https://linustechtips.com/topic/555871-msi-gaming-9-ack-help/#findComment-7324498
Yeah I thought about that M.2 slot after I asked you.
Thanks a lot, I truly do appreciate it!
https://linustechtips.com/topic/555871-msi-gaming-9-ack-help/#findComment-7324542
I'm not 100% sure it will work, but the info says it should.
Just so you know, if you run into any problems when building the PC.
https://linustechtips.com/topic/555871-msi-gaming-9-ack-help/#findComment-7324655
