I built my first system yesterday, and after setting up windows my ethernet isn't working so I can't install online drivers but only the ones that come on the disc the motherboard came with. I installed most things through the program on the disc but I can't install LAN drivers.
When I open Intel Network Connections it tries to install drivers but it says it can't find an Intel adapter. I'm not sure how to go about setting up drivers.
SPECS:
Asus Z97-A USB 3.1
i7-4790k
NVIDIA GeForce GTX 980 Ti
16GB HyperX Fury RAM
EVGA 650 G2
250gb 850 EVO
1tb WD Blue
Thanks.
https://linustechtips.com/topic/552956-help-with-ethernet-drivers/
You dont have like a USB Wifi card to plug in do you? If you do, plug that in and install the drivers for it. Then in Device Manager, look in "Unknown Devices" and look for the LAN interface in the list, Download drivers from there. Bing bang boom youre good to go
Desktop  - AMD Phenom II X4 955 - 12gb Hyper X DDR3 - NZXT Tempest - Asus M4A78DTX EVO - Gigabyte GTX 1050 Ti - 160gb Toshiba garbage - 1tb WD garbage
Laptop - HP Pavilion G7-2269wm - AMD A8-4500M - 6gb DDR3 - 320 gig Western Digital Scorpio drive - AMD HD 7640G graphics - 17.3 inch display
Server - x2 Xeon f41 2.80GHz - 4gb DDR ECC Reg - Intel Serverboard SE7320GP2 - ATI Rage 128 8mb - 120gb Seagate boot - 640 gb Network share
No USB Wifi card. I have a second PC with internet I can use but I've tried and I can't seem to get it to work.
Main Gaming and Streaming PC: http://pcpartpicker.com/user/Vinsinity/saved/TjwVnQ
Ultrabook and College Laptop:
XPS 13 9350:
i5-6200U
8GB RAM
Samsung PM951 250GB M.2 Solid State Drive
Workstation Laptop:
Sager NP8672 (P670SG):
i7-4720HQ
32GB (4 x 8GB) CORSAIR Vengeance Performance
Samsung 850 EVO 250GB M.2 Solid State Drive (Boot Drive)
Samsung 950 PRO 512GB M.2 Solid State Drive (Video Drive)
Crucial MX100 250GB 2.5" Solid State Drive (Secondary SDD Storage)
Western Digital (Blue or Black) 1TB 2.5" 7200RPM Internal Hard Drive (Storage Drive)
GeForce GTX 980M 4G
Id try and figure out what the exact model name/number is for the LAN chip and download the lastest drivers for it, If that doesnt work, try doing an OS reinstall, That worked for me on my laptop last time I reinstalled windows
1 minute ago, MW2Man00 said:
I'm running windows 7 and I've done that. I get a Code 31 error when I look at it in device manager.
Try uninstalling it and deleting the files and then redownload and try installing it again.
XPS 13 9350:
i5-6200U
8GB RAM
Workstation Laptop:
i7-4720HQ
GeForce GTX 980M 4G
How do I go about removing Windows 7 from my SSD
Just pop your install media into your pc and do the same installation process you did
I reinstalled windows with the same issue. When I go to install drivers from the Asus disk, it doesn't detect the network adapter.
First, I'd make sure the onboard LAN is enabled in the BIOS (I've done that before) and that it's visible in Device Manager as an unknown device. If so, try grabbing the driver straight from Intel on whichever computer you're sing to post here and pop it onto a USB stick to install on the new build. It's a newer driver than what comes on the disc anyway, and with any luck, you'll get some joy out of it.
