Hello
Do you cap your frame rate within NVIDIA Inspector or Afterburner like 143 FPS to stop going over the Gsync range (144hz) and to remove any screen tear, also do you enable V-Sync once you do this setting
Thanks
GPU[Two GTX 980ti Lightnings overclocked]-CPU[Core i7 5930K, 4.4Ghz]-Motherboard[MSI X99 Godlike]-Case[Corsair 780t Black]-RAM[32GB Corsair Dominator 3000Mhz Light bars]-Storage[samsung 950 Pro 512GB, Samsung 850 Pro 1TB and Samsung 850 Pro 512GB]-CPU Cooler[EK Predator 360mm]-PSU[EVGA 1600w T2 Individual cables Red]-Monitor[ASUS PG348Q]-Keyboard[Corsair K70 Red]-Mouse[Corsair M65 RGB]-Headset[sennheiser G4me one]-Case Fans[beQuiet Silent Wings 2]
https://linustechtips.com/topic/550072-gsync-frame-capping/
Is this just a general poll, or are you curious about the perfect settings?  If it's the latter, I think LTT did an extensive test of both freesync and gsync at a variety of framerates, with it and vsync used in different combinations that might be useful to you :)
https://linustechtips.com/topic/550072-gsync-frame-capping/#findComment-7262604
It is both really, I am interested if people actually cap their FPS with G-Sync then enable V-Sync
https://linustechtips.com/topic/550072-gsync-frame-capping/#findComment-7262619
Well I can't help you there because I've never used any of that stuff :(
but here's the video I was talking about:
https://linustechtips.com/topic/550072-gsync-frame-capping/#findComment-7262639
Thanks for the video
Does anyone else use frame capping
https://linustechtips.com/topic/550072-gsync-frame-capping/#findComment-7262689
