Flash Sites FREEZE help!
Go to solution Solved by riishalj,
It seem's to be working fine on Win 7
The programs i have installed are in picture, I have had an antivirus in previus Win 10 but for now i don't.
I will install an antivirus and see if that will have an effect.
3 hours ago, TonyStark said:
In general Flash is a dying technology. Even google stopped/will stop supporting it. Mostly everything will be converted to use HTML 5. Have you tried another site that uses flash ? (e.g. Youtube) If other sites don't freeze, then most likely is a server issue and not your computers. Furthermore do you use any antivirus, anti malware software ?
Youtube work's fine FLASH SUCKS !
I had avg and malwarebytes but malwarebytes was never working just when i was scanning
Hello,
I am having a frustrating problem with my computer for a long time now. Some websites I open (which I think are mainly flash) freeze my computer for good no matter how long I wait. Playing games does not affect pc in that matter.
The websites I can think of are (no links so it wont freeze again)
- Fifa ultimate team web app
- Bet365 a casino app window
- and some other but I mostly visit Facebook, Google and Youtube (neither of which freeze)
I was happening on Win 8, 8.1 and now in 10. I tried cleaning my PC, so every thing out and in again assuring good connections. Today I tried Ubuntu live CD (usb) and it froze again.
On windows and Linux I tried Chrome and Firefox the same thing
Could you please help me? It is so frustrating not knowing when it will freeze and destroy my work I may be working on.
Thank you in advance !
Haris
https://linustechtips.com/topic/549589-flash-sites-freeze-help/
4 hours ago, hman123467 said:
could be ur internet not loading fast enough or a faulty driver for your internet adapter
I do watch youtube a lot and Netflix on PC and TV and I have a raspberry Pi so I do use torrents for OS images. So I don't think it is speed or bandwidth.
Before i formatted i also had a VM of Windows 7 and it worked fine.
I tried to install Win 7 now but "it cant find drivers" probably preventing downgrading but if it wold work on Win 7 than that could be a clue.
https://linustechtips.com/topic/549589-flash-sites-freeze-help/#findComment-7283585
3 hours ago, hman123467 said:
try another HDD/SSD. it might be due to a bad sector
I installed it from Windows and it worked.
The video drivers are not installed and it seems to be working on Win 7
I will install Nvidia drivers now and see if that is the cause.
https://linustechtips.com/topic/549589-flash-sites-freeze-help/#findComment-7284313
https://linustechtips.com/topic/549589-flash-sites-freeze-help/#findComment-7284955
https://linustechtips.com/topic/549589-flash-sites-freeze-help/#findComment-7286283
