If you are still using mw600 surely ur clip must be broken..
This guide is for all the blutooth headset having clip..
I know i should have made a tutorial here..bt..i have recently made a perfect guide on
Instructables
So you can
Check out this awesome Instructable.
http://www.instructables.com/id/Fix-Your-Bluetooth-Headset-Clip
https://linustechtips.com/topic/546912-bluetooth-headset-clip-fix/
