Help with extra upgrades.
Go to solution Solved by Wouterrinos,
Just now, Wooosh__ said:
Hey @Wouterrinos dankjewel dat je me weer helpt :P de video kaart is alleen 1mm te groot voor de case, dan moet ik een bay eruit halen ik weet alleen niet wat voor gevolgen dit zou opbrengen...?
If you take a bay out, you'll just have on spot less for an HDD or an SSD, but you'll have enough left, so don't worry.
Other options are a different case ( Mastercase pro 5 is great) or switch the Gigabyte 980ti for a Msi/Evga.
Hello guys,
yesterday i asked the community for a good i7, GTX 980 Ti build and i recieved a good one, a good friend of mine made some improvements on it and this is the outcome: http://pcpartpicker.com/user/Wooosh__/saved/CrdZxr now i'm asking you guys if i have to improve it some more (fans, sound-card and such) if needed or are the results good?
Thank you for responding and have a nice day.
Wooosh__
https://linustechtips.com/topic/546592-help-with-extra-upgrades/
Avoid that PSU and just go for the EVGA B2 750W. Hell, a EVGA G2 650W will be enough if you're not planning to SLI.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/546592-help-with-extra-upgrades/#findComment-7226482
@Wooosh__
http://pcpartpicker.com/p/YqrG7P
- Better cpu cooler (and a lot cheaper weirdly)
- Better mbo
- Bigger SSD
- Niccer case for a Nice build ( can be change according to your taste ofcourse)
- Great psu
- Windows 7 pro ( free upgrade to 10 pro) here for almost no money : https://www.reddit.com/r/microsoftsoftwareswap/ or G2A.com
https://linustechtips.com/topic/546592-help-with-extra-upgrades/#findComment-7226499
https://linustechtips.com/topic/546592-help-with-extra-upgrades/#findComment-7226533
