Hello everyone, thanks in advance for your time and sorry for my English, I’m italian.
Basically I’m not so sure on how to configure my LAN. Right now I use a Netgear DGND3700v2, modem + router ADSL2+ dual band with a top speed of 600Mbit (300 + 300). This device is located in the center of my home, the only place where I can plug it into, and it handle very smoothly over wifi 3 PCs, a bunch on mobile devices, a console and shortly a NAS that I’m going to build + some smart TVs.
What I need is a wired connection for my desktops, console and NAS, in order to get the theoretical 1Gbit data transfer mainly between the NAS and the PCs. Plus I need a wireless connection for the smart devices capable of handling 1080p (4k in the future) streaming.
Since I have an old core 2 duo lying around I thought that I could built a pfsense router (I wanna try) and use the Netgear as modem only. All the PCs, NAS... and the future pfsense router are in the same room and I already have a 10m Ethernet cable to connect the new router to the Netgear.
Here is my question: Can do something like this? Or I should buy an AP? Or there is a better way?
Netgear(modem) ----> pfsense(router)
pfsense(router) ----> Netgear(AP) ----> Mobile
pfsense(router) ----> switch ----> PCs/NAS
So, I want a wired connection for computers and console, a wireless connection for streaming 1080p/4k. I already have the hardware for a pfsense router and I would really like to use it. I’m open to suggestions and I have some money if I need to buy something else.
https://linustechtips.com/topic/546522-help-home-network-configuration/
You won't be able to use the netgear as both a modem (WAN) and AP (LAN) - unless I misunderstood and you have two netgear devices. The recommendation with PFsense routers is to use dedicated APs, or consumer routers configured to work as APs.
Looking to buy GTX690, other multi-GPU cards, or single-slot graphics cards:
1 hour ago, matteobad said:
Thanks for your answer. Another question come to mind... Would it be possible to use a PCI wireless card to use the pfsense router as AP too?
Do you have any suggestions for a good AP, or PCI card if possible for around 100€?
it is possible but pfsense has really bad wireless support, and people who set it up generally aren't happy with the results. Also last I checked (a few months ago) they still didn't have MIMO or 802.11ac support.
