Ok, my external cable management is crap. It's WW2.
I've heard of some Ikea Segnum or something.. not sure what it is
Requirements: Needs to be easily moved (cables have to be able to be moved around easily when needed)
Would like it to look good and not just "hold the cables off the ground"
Any ideas would be appreciated :)
Intel i7 6700K | MSI Krait Z170A MSI GTX 980 w/ NZXT Kraken G10/x31 Corsair Vengeance LPX 16GB Samsung 850 EVO 500GB SSD/WD Blue 1TB HDD NZXT H440 | K70 RGB/SteelSeries Rival
https://linustechtips.com/topic/544522-external-cable-management-ideas/
The IKEA Signum rack is all right.
Also, twist ties and 3M tape are your best friends.
Other systems I've built:
Cable management is tough for me, I have a glass table top.
You could try to get some velcro wrap of some sort, instead of tape or zipties. And after doing that, get some plastic wire tubing from home depot, and group them all into the tubing.
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
