over these last few years i have been saving up to build a brand new desktop and i don't really know what im doing when it come to computer building so i was wondering if anyone can help pick out the best requirment for my pc.
Budget: 800-1000$
Interests:Gaming,School Work
https://linustechtips.com/topic/544063-help-build-my-pc/
Budget: 800-1000$
What resolution do you plan on playing at?
CPU: i7-8700K I CPU Cooler: Noctua NH-D15 GPU: ROG Strix 1080 Ti MoBo: ROG Strix Z370-E RAM:  G.SKILL Ripjaws V Series 32GB (2 x 16GB)   PSU: CORSAIR HXi Series HX1000i Case: Corsair Air 540 Display: 24" 1920X1080p 144Hz ASUS - 27" 2560X1440p 144Hz Dell OS: Windows 10 Home 64bit
https://linustechtips.com/topic/544063-help-build-my-pc/#findComment-7197865
I think I have one :)
Also, this is for 1080p gaming...
PCPartPicker part list: http://pcpartpicker.com/p/tHzmYJ
Price breakdown by merchant: http://pcpartpicker.com/p/tHzmYJ/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($224.95 @ SuperBiiz)
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler  ($46.99 @ Newegg)
Motherboard: Asus Z87-Pro ATX LGA1150 Motherboard  ($76.99 @ NCIX US)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-1866 Memory  ($69.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Video Card: MSI Radeon R9 390X 8GB Video Card  ($388.98 @ Newegg)
Case: Thermaltake Core V51 ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.99 @ Newegg)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($86.89 @ OutletPC)
Total: $1060.66
Generated by PCPartPicker 2016-02-08 20:32 EST-0500
              PC Specs:
CPU: i7-5930K | Cooler: Corsair H100i GTX | GPU: GeForce GTX 980 Ti | Mobo: ASRock X99 Extreme4 | Memory: HyperX Fury Black 16GB | Storage: SeaGate 2TB & SanDisk 120GB SSD | Case: Fractal Design Define R4 w/ Window | PSU: EVGA SuperNova 750W Gold Cert | Monitors: (x2) Acer S220HQL | Keyboard: Razer Blackwidow Chroma | Mouse: Corsair M65 RGB |
https://linustechtips.com/topic/544063-help-build-my-pc/#findComment-7197881
I know it's gross to even think about but you could use the stock cooler to cut down on costs and buy one a little later once you have the funds. But other than that, the build that @UGame_ posted is solid and should be able to run ultra at 1080p at 60FPS easily.
https://linustechtips.com/topic/544063-help-build-my-pc/#findComment-7197903
