Camera Advice Appreciated
First thing I will say is to check the links in my signature.
Second, your maximum budget is $1000.00? Is that just for a camera (and lens) or are you also considering buying supporting equipment?
For photography, starting out with a camera, lens, memory card, spare battery is often enough. For video just having a camera, lens, memory card and spare battery is not often enough. You also have to think about investing in an external microphone for recording clean audio as often internal microphones are not enough. And you have to think about investing in at least one external light that can be mounted on the camera.
Furthermore, a photo is a capture of a frozen moment in time. With a fast enough shutter speed and the assistance of image stabilization capturing a sharp clean looking image while holding the camera only with your hands is doable.
Video is recording a series of continuous moments that are spread across time, without a gimbal style image stabilizer or steadicam harness or dollies and sliders or the support of a tripod system, there is always a good chance that you will not be able to do smooth camera movement. Camcorders such as Sony's Handycam have built in gimbal style image stabilization systems, which are designed and optimized for video. In the guide I wrote (linked in my signature) there are videos comparing a photo camera IS to a video camera IS.
How important is it for you that camera performs better for video or for photo?
If you are not good with cameras, I recommend you consider using a camcorder for video and perhaps a compact camera for photo. $1000.00 will get you two good cameras, one for each task.
