2 minutes ago, verydogesuchwow said:
What are sticky corners?
Im assuming it is something with window tiling. Im not sure where to find the setting but ill look around a bit. and then edit this post.
*EDIT*
Settings/System/Multitasking/snap
 Pc Speck's : i7-6700K 4.0GHz , GTX 980 Ti G1 Gaming 6GB , 16 GB Corsair Vengance DDR4 - 3400 , ROG SWIFT PG278Q 144Hz , (2) Acer G277HL bid 60Hz.
https://linustechtips.com/topic/540852-help-with-sticky-corners/#findComment-7162331
3 minutes ago, woodsy said:
its when you have dual monitors and you try to move your mouse across one screen to another and the mouse gets stuck because you didnt move it fast enough. at first its not that bad but after awhile its the most irritating thing ever
Im using windows 10 on 3 monitors.. i have never seen or heard of this.. are you sure you have your monitors aligned "digitally"?
https://linustechtips.com/topic/540852-help-with-sticky-corners/#findComment-7162341
