hi there i was hoping u guys can help me on a portable build. any suggestions would be awesome
1. Budget & Location
around 1000-1500 usd
2. Aim
im a gamer (obviously) i was aiming for a portable system (i know laptops exist) building something you can put carry around and plug onto a socket and go.something that can handle gaming and perform tasks on video editing and in line with photography. more like an all in one type but custom casing and the monitor is just mounted on the side or something like that
3. Monitors
one but will be able to support up to 3 monitors
4. Peripherals
keyboards and mouse. wireless would be nice but theres this video of yours where the mouse and keyboard are resting on a custom platform it was about couch gaming or something
5. Why are you upgrading?
a portable desktop so in case of future upgrade or changing parts
https://linustechtips.com/topic/539471-need-help-on-a-crazy-build/
Well the Elite 110 is about as small as it gets without going into GPUless or SFX territory
Otherwise did you mean to use it with a USB display or something?
You could use one of those external GPU solutions as well ya know, though I think currently they're fairly expensive
PCPartPicker part list: http://pcpartpicker.com/p/cMKx4D
Price breakdown by merchant: http://pcpartpicker.com/p/cMKx4D/by_merchant/
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($244.99 @ SuperBiiz)
Motherboard: ASRock H97M-ITX/AC Mini ITX LGA1150 Motherboard  ($89.99 @ SuperBiiz)
Memory: Corsair 16GB (2 x 8GB) DDR3-1600 Memory  ($78.99 @ Amazon)
Storage: Sandisk Ultra II 480GB 2.5" Solid State Drive  ($133.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Video Card: XFX Radeon R9 Nano 4GB Video Card  ($534.98 @ Newegg)
Case: Cooler Master Elite 110 Mini ITX Tower Case  ($38.99 @ SuperBiiz)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($72.99 @ NCIX US)
Total: $1244.81
Generated by PCPartPicker 2016-02-02 01:43 EST-0500
2. Aim
3. Monitors
4. Peripherals
someone just had something similiar
my suggestion:
http://pcpartpicker.com/p/YQQN3C
1 minute ago, Josephdalepi said:
someone wondered about the 6700k
simple
not only is it amazing
but leaves a shitload of rooms for upgrades if you take it out of itx
Ya. Also it is sky lake so it's the newest architecture. I think it's nice just to have the newest stuff possible.
