3:! CPU Cooler under 70 dollars
Kenji the Uke
SO YES! As the title says Thats my budget with shipping included. owo I have done a look on PCP and So many brands I havnt heard of in the upper range.. The thing I am looking for is it has to be quiet, but I am looking to overclock a 3570k to atleast 4.4 .w. with Temps under 60C
IGNORE THE 3: Its a face .w.
Moist
Its a face, ignore it x-x
ah the way i read it was that you have 3: to spend on a cooler xD not in the tittle but in the post
1010011010/29A
M-my bad ;w;
Moist
my friend has this and says it works really good ww.newegg.com/Product/Product.aspx?Item=N82E16835608018 $10 over tho
1010011010/29A
That is something I was wanting.. but sadly ;w; I cant go over budget even a bit..
Moist
Those are all awesome, but the shipping isnt free ;w;
Phanteks one is well within budget, and Newegg has free shipping on it. It's a pretty good cooler, too.
yeah usually if a person says they can't go over i assume its a present and thats why. like your parents say we can spend this much for christmas so tell me what you want, and you can't go over
1010011010/29A
coolmaster hyper 212, its 30$ on amazon (prime) and newegg, and has loads of great reviews
yes but he has $70 he can get a way better one for $70 but i would recommend the 212 evo, i have one myself
1010011010/29A
I definitely dont mind beefy :3 I have a huge case so it will fit pretty much anything
You may need to look into RAM clearance on the double heatsink ones like the first Raijintek one I posted. If you have high profiles RAM, the fan may not clear it.
Cryorig H5, Cryorig R1
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
I have unknown PCB exposed ram 3: So it should be fine
I may consider the H5 owo
Moist
What kind of dollars are you using?
Why under 60c? You're fine up to 90c at load.
Because Intel's website said the maximum temp for the processor 3570k is 67 3:
And USD.
Moist
And USD.
67.4c is the max temp for the ihs and not the cpu core. The cpu stops running when the cores reach 105c.
Depending on how much you want to spend, H7: http://pcpartpicker.com/part/cryorig-cpu-cooler-h7
Pure Rock: http://pcpartpicker.com/part/be-quiet-cpu-cooler-bk009
or Kotetsu would be fine: http://pcpartpicker.com/part/scythe-cpu-cooler-scktt1000
3: Hmm. Those are pretty tempting.. AND I SEE OWO
Moist
