CPU fan error.
Go to solution Solved by ★ Coups ★,
Your cooler has a fan connector that needs to be plugged into a specific fan header on your motherboard for RPM to be reported.
It's usually marked 'CPU_FAN' on the motherboard, so you need to locate that and plug the connector in.
Yeah. Its usually at the top of the motherboard.
I was re arranging some cables and I turn my pc on with a x61 kraken and its not detecting rpm anymore ??? Help
| CPU: Core i7-4790K  |  Motherboard:  MSI Gaming Z97 GAMING 5 LGA 1150  |  CPU Cooler:  NZXT Kraken X61 |
| GPU: Single 8GB EVGA GTX 1070 FTW |  RAMCorsair Vengeance 16GB (2 x 8 GB) DDR3 1600 MHz |  CaseCorsair 330R Titanium Edition
https://linustechtips.com/topic/537107-cpu-fan-error/
CPU - i7-4790k | CPU Cooler - NZXT Kraken X53 | Motherboard -  Asus Gyphon Z97 Armour Edition | RAM - Corsair Vengeance (2x8GB) 2400Mhz | Graphics Card - MSI GTX 1070 | Power Supply - Corsair CS750M | Storage - Seagate 1TB HDD | Samsung 500GB 850 Evo | Case - Fractal Design ARC Mini R2 | Colour Theme - Generic Red & Black
Operating System - Windows 10 Pro | Peripherals - Corsair RGB Mechanical K70 Keyboard/Corsair M65 Mouse
Click here to give a damn
https://linustechtips.com/topic/537107-cpu-fan-error/#findComment-7123796
