So, after watching people build pc's like it's nothing and having listened to Linus repeatedly say to tighten the screws in a cross pattern, I am finally ready to build my first ever gaming pc.
However I would like to be sure that it is going to work, and that I don't have to face many challenges building it. Also I would be open to any tips you guys have.
Here's the plan (http://pcpartpicker.com/p/2pGc23)
  • <CPU >Intel Core I5-6600K
  • <CPU cooler> Cryorig R1 ultimate cooler
  • <Mobo> MSI Z170A Gaming M5
  • <RAM> 2x8GB Corsair DDR4-2133
  • <Storage> Samsung 850 Evo 250GB SSD + 3TB Seagate Barracuda
  • <GPU> Gigabyte GTX 980 4GB Winforce 3X
  • <PSU> Corsair CX 750W
  • <Case> NZXT Noctis 450 ATX mid tower
The budget lies at a maximum of 1400 USD (excluding peripherals)
https://linustechtips.com/topic/535806-my-first-ever-build/
I'll see if I can do better. Do you have Windows?
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/535806-my-first-ever-build/#findComment-7107740
The PSU is bad , the HDD is bad and I would recommend R9 390x over the GTX 980.
Main PC: CPU Xeon E3-1231 V3 - MB Asrock B85M Pro3 - RAM 16GB Kingston - GPU GTX 1070 Gainward Phoenix - PSU Corsair AX760i - Monitor  LG 22EA63 - Keyboard Corsair Strafe - Mouse Logitech G402 - Storage 2x3TB WD Green - 240GB OCZ SSD
https://linustechtips.com/topic/535806-my-first-ever-build/#findComment-7107748
Changed a couple of things.
CPU Cooler: Phanteks PH-TC14PE_BK 78.1 CFM CPU Cooler  ($69.99 @ Newegg)
Motherboard: MSI Z170A GAMING M5 ATX LGA1151 Motherboard  ($152.98 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($84.98 @ OutletPC)
Video Card: Sapphire Radeon R9 Fury 4GB Video Card  ($506.98 @ Newegg)
Case: NZXT Noctis 450 ATX Mid Tower Case  ($117.99 @ Directron)
Total: $1389.77
Generated by PCPartPicker 2016-01-27 12:58 EST-0500
Stronger GPU, better PSU, cheaper cooler that performs the same/better.
https://linustechtips.com/topic/535806-my-first-ever-build/#findComment-7107758
Total: $1389.77
I'd go with this build but get a WD hard drive over the Seagate
~2Bangz~
https://linustechtips.com/topic/535806-my-first-ever-build/#findComment-7107800
But the 980 is faster
Its 100 bucks more expensive, if wasnt faster I would be really surprised, just doesnt compensates.
https://linustechtips.com/topic/535806-my-first-ever-build/#findComment-7107806
The HDD is fine, I have one, but the PSU, not okay, just put in a EVGA/XFX/Antec PSU...
EVGA and Antec both have some sub-par units in their lineup. EVGA has some terrible ones. XFX uses Seasonic only as OEM, so they're safe, but you need to be specific with the models for brands that use a variety of quality OEM units.
https://linustechtips.com/topic/535806-my-first-ever-build/#findComment-7107828
True..The higher end EVGA PSUs like the Supernovas are good for his build...
I am  MCCCXXXVII
https://linustechtips.com/topic/535806-my-first-ever-build/#findComment-7107841
You can a better cooler i​n later when you have more $$$ available
Generated by PCPartPicker 2016-01-27 13:08 EST-0500
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/535806-my-first-ever-build/#findComment-7107852
Depends on the unit. The NEX (G1) series are part of the SuperNOVA line, but are not great. The B2. GQ, GS, G2, PS, P2 and T2 are the good units.
https://linustechtips.com/topic/535806-my-first-ever-build/#findComment-7107862
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($249.99 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.88 @ OutletPC)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($153.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2133 Memory  ($72.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.88 @ OutletPC)
Video Card: EVGA GeForce GTX 980 Ti 6GB FTW ACX 2.0+ Video Card  ($639.99 @ Amazon)
Case: NZXT S340 (White) ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.99 @ Newegg)
Total: $1415.68
This is the best build here.
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/535806-my-first-ever-build/#findComment-7107864
