Need help with the air flow of the case not sure my current set up is any good since every one recomence setting up radiator on top as exaust.i have the radiator pushing air and the left side one pulling air plus the two right ones pulling air in.will this set up be ok or should I configure another way
post-294048-0-95371800-1453342472_thumb.
post-294048-0-91210500-1453342539_thumb.
https://linustechtips.com/topic/531379-need-help-setting-up-pc-for-first-time/
you should turn the one right up against the gpu so its blowing air onto the card so the fans actually have something to pull away from the heatsink. there may even be a deadspot on your card which will make dust collect much faster
The top is pushing air into the case the two front ones are pulling air in and the back fan is pushing air out I put the fan right in front of the gpu too keep it more cool
Should I put the top fans of the radiator to pull air out of the case or this is fine I only did it because later I am getting red fans
