So there are a few limiting factors with older GPU's and eyefinity.
Some of these may or may not be applicable to you.
You can only use 2 of the DVI/HDMI outputs at one time. (If you have 2 DVI plugged in you can not use the HDMI port; 1 HDMI & 1 DVI means the other DVI port doesn't work.)
To use eyefinity you must use active adapters to convert a signal, So the signals coming from the card are the same.
Do your monitors have any inputs other than VGA?
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
https://linustechtips.com/topic/528300-amd-eyefinity-problems/#findComment-7016359
First of all, there are no AMD GPUs supporting Eyefinity that cannot utilize at least 3 monitors.
Second, i would take a look at the AMD software, maybe there are some settings you overlooked. I cannot help you with this bit, the last AMD i had was the 7970 and i only went for two monitors back then and drivers have changed.
Third, if all else fails. I would try to use the two DP ports + HDMI/DVI. You may need to use adapters.
Motherboard: Asus X570-E
CPU: 3900x 4.3GHZ
Memory: G.skill Trident GTZR 3200mhz cl14
GPU: AMD RX 570
SSD1: Corsair MP510 1TB
SSD2: Samsung MX500 500GB
PSU: Corsair AX860i Platinum
https://linustechtips.com/topic/528300-amd-eyefinity-problems/#findComment-7016430
