Make sure you have Cloud Saving enabled, then Steam should automatically transfer your saves when you install. As for mods, those have to be reinstalled.
I'm a fucking AMD kawaii weeaboo desu I have seen the light
i5 6600k EVGA 980 FTW Z170A PC Mate 1TB WD Blue240GB SSD Plus NZXT S340 | EVGA 600b  | Dedotated 8GB
https://linustechtips.com/topic/526120-selling-pc-need-help/#findComment-6982987
what do u mean copy your save files across to the new pc
If you look in your documents folder on your account (Windows), you should see a My Games folder, which should have your save files in it. I don't think the game saves are stored in the cloud (unless you specifically tell Steam to do so)
https://linustechtips.com/topic/526120-selling-pc-need-help/#findComment-6983040
Find the folder with all the fallout game data in it and find the saves. Literally copy and paste them onto a thumb drive or something and tada!
The saves are usually separate from the game data. The game data is normally in Program Files, while saves tend to be somewhere in the User's folder. So normally: "C:/Users/*Username*/Documents/My Games/Fallout 4" or somewhere after "/Documents"
https://linustechtips.com/topic/526120-selling-pc-need-help/#findComment-6983054
This. Forgot about that to be honest.
https://linustechtips.com/topic/526120-selling-pc-need-help/#findComment-6983076
