M.2 storage solution for new build
Go to solution Solved by warzkaz,
best m.2 ssd is Samsung 950 pro
absolute amateur with first build
· ASUS X99-Delux 1 Motherboard
· Intel Core i7-5820K Six Core Processor 3.3GHz
· Quadro K2200 4GB Graphics card
· Memory DDR4 3000 mhtz 16GB
 what M.2 drive for  OS and applications?
I was planning a Samuung XP941  512 GB
 My main application is Photoshop not gaming
the next question will be a case and water colling for box not CPU
https://linustechtips.com/topic/523642-m2-storage-solution-for-new-build/
What is your total budget? It is possible that we might be able to put together a more powerful build for you - for example, such an expensive motherboard is not necessary, and the money could be invested in other areas.
Amd phenom ii x4 955 Asus crosshair iv formula Kingston hyperx fury 8GB 1600mhz ASUS Radeon R9 280X DirectCU II
Cooler master haf xb evo Antec 750w 500gb wd black BenQ gw2760hs Samsung 850 EVO 250GB 2.5" Solid State Drive
 I have purchased the X99 Asus Delux motherboardthe
Intel i& 5820K procesor
and have Ceil quad channel kit of ddr4  2400- 30000HHx  4GB X 4  QC kit so 16 GB which should be more trha adaquate
My photoshop file get to 200 MD  and my 5 yeard old system struggles.  I was a syster to last another five years
the budget is not a real issue   I could doubble the RAM  so take it from 16 to 32 GB  on the motherboard
I have a Coolmaster Hyper 212 EVO cpu cooler
I was planning a SSD and a 2 TB hard disk    there are 2 M.2 slots on the motherboard    - what the hell    I have the tech I want to use it so I will get a M.2   stroage just because  I can
I will not need to force greater performange from the system  so npo overclocking planned.
m.2 ssd is Samsung 950 pro  looks great    512 GB anticapted   thanks warzkaz
my pleasure   :)
