Worker 4 not working.. overclocking
Go to solution Solved by TheCarGuy94,
passed it totally fine all the way from 3.5GhZ to 4.3GhZ just wont finish on 4.4
(done the test each time i changed voltage or core clock)
So ive be reading up on overclocking and thought id give it a try.
adding core multiplier and some voltage little by little. I managed 4.3ghz at 1.176V with temps of 55C the i went up to 4.4GhZ (same voltage). got into windows started a stress test and i got this message fro Prime 95 only on worker/core 4.. Any ideas what this could be or if ive done anything wrong.
post-298435-0-56778500-1452289891_thumb.
                     Intel i5-6600k @4.6    Gigabyte GA-z170mx     KF2A GTX970     Samsung 120gb ssd     Corsair RM650x     Corsair Air240     Avexir 8gb DDR4
https://linustechtips.com/topic/523248-worker-4-not-working-overclocking/
you failed the test
does it fail the test at stock?
if it's failing at stock RMA
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
