Hi guys,
So, I'm in the process of saving up for a new PC however I'm debating buying the GTX 980 TI and putting it in my current build and then transferring it to the new build when I get it.
My current specs are -
650w PSU
Core i7 4770
8GB Ram
GTX 770
Is it worth buying the 980ti now and using it whilst I save for the rest of the computer or should I just buy it all in one go? Only reason I ask as I've been told my CPU isn't that bad and shouldn't bottleneck the 980ti so they said I should get the 980 now and the rest when I can but I wanted some other opinions.
Thanks,
Dan
Edit - Should probably add, the reason why I'm getting a whole new computer is because my motherboard is pants, it's the Gigabyte h81m-h.
i9 9900k | RTX 3080 TUF Gaming OC | 32GB Vengeance LPX 3000Mhz DDR4 | Gigabyte Aorus Master Z390
https://linustechtips.com/topic/523201-gtx-980ti-help-please/
Yes. It doesn't change anything, as long as your psu has the power cables.
Which I'm assuming it does as the 770 has the same connections as the 980ti.
Man, I can see I'm in for a bumpy ride learning all the ins and outs of PCs but something I'm looking forward to!
https://linustechtips.com/topic/523201-gtx-980ti-help-please/#findComment-6948071
Hi guys,
650w PSU
Core i7 4770
8GB Ram
GTX 770
Thanks,
Dan
While a 980 ti is great, I'm waiting to see if Nvidia releases any new gpus this year (which they most likely will). I'm waiting for the successor to the gtx 980. (which would be 1080 maybe, if they continue the naming trend)
https://linustechtips.com/topic/523201-gtx-980ti-help-please/#findComment-6948195
As I said, I'm new to the PC market, would you suggest waiting? Or will the new GPU range be alot more expensive than the 980ti?
https://linustechtips.com/topic/523201-gtx-980ti-help-please/#findComment-6955131
