Some that I can think of is lower temperatures. If using a 7xx series from Nvidia GPU boot 2.0 correlates with temperatures. The cooler the card the higher it can boost its self up. Also water cooled cards are quieter.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/52121-water-cooling-gpus/#findComment-697276
It looks really nice in rigs and is cooled better. With gpu boost you get more performance because it will boost itself up to a certain temp. Not sure on oc because my 770 was pre overclocked.
My rig  case- Graphite 600t white CPU-i5 3570k OC 4.0Ghz RAM- 8gb Vengeance memory HDD-WD Black 1tb PSU-tx650 GPU- MSI 770 gameing edition 2gb , gtx 650 1gb Motherboard- asrock extreme 3 z77 Fan controller- NZXT sentry lx CPU cooler- H60 Peripherals- g300 mouse G630 headset k70 silver cherry mx red switches  my free nas nas Case- Dell something.. Ram- 8 gb ecc ddr 2 CPU - Pentium D 3.0ghz HDD currently 160 gb adding 3tb wd red “Sucking at something is the first step to being sorta good at something” –Jake the Dog
https://linustechtips.com/topic/52121-water-cooling-gpus/#findComment-697282
Why have a hot GPU when you can have a cool GPU?
It's like asking "why have a gaming PC if a office PC can run a game?"
Also, some cards benefits having cooler temperature.
This. Also, any component will last longer if it is kept cool.
That and watercooled multi GPU setups look so sexy :D
Fractal Design Define S, i7 3770K @ 4.5GHz, Noctua NH-D14, Asus Sabertooth Z77, EVGA 980Ti SC+, 4x8GB Corsair Vengence 1600MHz, EVGA P2 1000W, Creative sound blaster Z, 2xSamsung 850 120GB RAID 0, 2xWestern Digital Caviar Black 1TB Other stuffs: BenQ XL2411t, LG Flatron M2262D, Ducky Shine 3, Logitech G400s, Steelseries QCK Heavy, Beyerdynamic DT770 pro 80ohm, Shure SE215, Blue Snowball
https://linustechtips.com/topic/52121-water-cooling-gpus/#findComment-697288
Runs cooler, quieter and the aesthetics are very appealing.
CPU: Ryzen 5 3600 @ Stock, CPU cooler: Dark Rock 4, Motherboard: MSI B450M PRO-M2 MAX, RAM: 2x8GB Crucial Ballistix DDR4 @ 3000Mhz, GPU: EVGA GTX 1080 ACX 3.0, SSD: Crucial P1 1TB M.2 + 2x120GB SSDs, Case: Corsair 110R, PSU: Corsair TX650M, OS: Windows 10 64-bit.
https://linustechtips.com/topic/52121-water-cooling-gpus/#findComment-697334
Cooler GPU = Able to overclock higher as most GPUs are limited by temps first then voltages.
CoolerMaster CM 690 II Basic | Intel i7-2600 | CoolerMaster Hyper 212+ 2x Zotac GTX 1070 AMP! Edition
Asus P8Z77-V LK | 2 x 4GB Kingston HyperX DDR3 1600MHz CL9 | SeaSonic M12ii 850W 80+ Bronze Crucial M4 128GB
https://linustechtips.com/topic/52121-water-cooling-gpus/#findComment-697487
When the 900 Series comes out (or 800 series depending on performance difference from 780) I'm gonna get a full GPU water block for my x80 nvidia card and commit to water cooling both GPU and CPU. I'm only worried that I'll have to mod the crap out of my current case to make it work the way I want (HAF 932)
CPU: 3570K @ 4.3Ghz MOBO: ASUS P8z77-v Deluxe RAM: 2-4GB Gskill GPU: EVGA 670 FTW SSD: Vertex 4 256 Case: CM HAF 932
https://linustechtips.com/topic/52121-water-cooling-gpus/#findComment-697497
